| which distributor to us https://slantsix.org/forum/viewtopic.php?t=48317 |
| Author: | stolan83 [ Tue Mar 27, 2012 10:10 am ] |
| Post subject: | which distributor to us |
I have two different distributors, A mopar performace stock hei and one that has a ingnitor 2 that has been recurved. The only shop that i could find that will recurve the HEi on charges 100 hour for labor and then parts. what should it do? |
| Author: | SlantSixDan [ Tue Mar 27, 2012 10:42 am ] |
There is nothing such as a "Mopar Performance stock HEI" distributor. If you mean that you have a Mopar Performance electronic ignition distributor, it would have come with extra-light advance weight springs. Not suitable for use on the street. |
| Author: | DusterIdiot [ Tue Mar 27, 2012 5:28 pm ] |
| Post subject: | ???? |
If you have a car set up for points already run the ignitor...If you have EI, get the other one recurved (if it's a MP distributor and you are only drag racing-plug and play)... do you have a part number tag on the EI unit? -D.Idiot |
