It is currently Wed Apr 29, 2026 11:51 am
 Post subject: 7 1/4 change to 8 3/4?
PostPosted: Thu Jan 16, 2003 4:22 pm
Thinking about a change of the 7 1/4 housing to a 8 3/4 in my Scamp.
I know I have to change the shock mounting plates, what else will have to be changed? backing plates & etc?
 Post subject: What Year Scamp...
PostPosted: Thu Jan 16, 2003 10:06 pm
Does the car have the small 5 on 4 lug pattern or the bigger 5 on 4 1/2?
You will need the shock plates, U-bolts and the driveshaft eill need to be shortened about 1 3/4 inches
 Post subject: bolt pattern
PostPosted: Fri Jan 17, 2003 4:32 pm
Doug, it has the 5 lug 4" bolt pattern. IM really curious if my backing plates will work.
PostPosted: Sat Jan 18, 2003 7:25 am
Nope...the backing plates won't work. I tried it over the summer :shock: I even re-drilled 'em on a drill press. You have to get the brakes from an 8 3/4" rear.
'68 Dodge Dart 4dr Sedan
