| oil in top of my coil https://slantsix.org/forum/viewtopic.php?t=48355 |
| Author: | 1970-dart [ Sun Apr 01, 2012 6:00 am ] |
| Post subject: | oil in top of my coil |
as i was working on my car I found the top of my coil full of oil. While the car is still running fine I would assume this is not good and I should think about replacing the coil asap. Which brings the question should I just replace the coil or consider a electronic distribute and if so what should I look for and what does the install require for wiring. Does anybody here have one for sale ?? thanks in advance and now I'm off to do some forum research on coils and distributors |
| Author: | SlantSixDan [ Sun Apr 01, 2012 9:51 am ] |
Definitely a good time to put in a better ignition system. I strongly recommend the HEI upgrade. |
| Author: | hantayo13 [ Mon Apr 02, 2012 6:21 am ] |
atleast replace coil...it is leaking coolant oil & will stop working |
| Author: | 1970-dart [ Mon Apr 02, 2012 1:20 pm ] |
i will prob just replace the coil for now.. what coil should i use |
| Author: | SlantSixDan [ Mon Apr 02, 2012 1:42 pm ] |
A Standard/BlueStreak or Echlin stock replacement. |
| Author: | 1970-dart [ Mon Apr 02, 2012 2:59 pm ] |
perfect Thank you Sir |
