A-body Lower Ball Joints
https://slantsix.org/forum/viewtopic.php?t=48368
Page 1 of 1
Author:  Old Car Scott [ Mon Apr 02, 2012 10:28 am ]
Post subject:  A-body Lower Ball Joints
Whats the difference between the drum brake 67-72 lower ball joints and the 73-76 lower ball joints? Is it fastener size or are the mounting holes spaced differently?
If it's the fastener size I'm thinking I can drill the holes oversize and use the later cheap LBJs.
I don't really want to buy somewhat expensive new early LBJs for a car I plan on upgrading when I find parts to replace the '73+ disc brake swap stuff that was damaged in the accident of my old Valiant.
Thanks!
Author:  Doc [ Mon Apr 02, 2012 4:44 pm ]
If for the Disc Brake set-up, the two listed ball joint types have different forging shapes... it is not simply a hole size difference.
