| what length pushrods should I order? https://slantsix.org/forum/viewtopic.php?t=48415 |
| Author: | Valleyant [ Thu Apr 05, 2012 8:44 pm ] |
| Post subject: | what length pushrods should I order? |
The car has provided better power and mileage since the super six conversion on my '72 Valiant with 225 but I am battling rocker arm adjusters that are backing off and causing the valvetrain to become noisy. I want to fix this since this was never an issue before I had the head milled. I had .085 milled from the head and used a felpro head gasket. should I order pushrods that are shorter by the milled amount and headgasket difference from stock steel shim to felpro? I had to back the adjusters about 2 full turns when the head was milled and then tightened them accordingly to get the lash set. I will pull the valve cover to see how many are affected. Would you guys just try to fix/replace the loose rocker arms? I have found one slant at the yard that I can buy the rocker assembly from. Just wondering what would be the smartest route to correct this....thanks! |
| Author: | emsvitil [ Thu Apr 05, 2012 8:57 pm ] |
A jam nut on the rocker arms should do the trick...... |
