It is currently Fri Jun 12, 2026 12:10 pm
 Post subject: rebuild help
PostPosted: Fri Apr 06, 2012 8:27 am
So my gearbox is slipping 904tf from a down under (aussie) 67 vc valiant. Would something like this:
http://www.ebay.com.au/itm/TORQUEFLITE- ... 27c58f0bcb
Fix a problem of slipping out of gear, or not engaging into gear straight away.
It's a very cheap alternative, it's not easy to come by these gearboxes where I am and a full rebuild was quoted to me at $1000 total from two local shops.
Thanks for the help!
PostPosted: Fri Apr 06, 2012 8:31 am
Start with doing a full service on the unit, inspect the junk in the trans pan, once its off, for a better idea of the unit's condition.
Often a clean filter, new fluid and increasing the main line fluid pressure will help the problems you discribe.
If there is a lot of friction material or metal in the pan... it's time for a rebuild.
PostPosted: Sun Apr 08, 2012 5:48 am
Thanks DOC!
PostPosted: Sun Apr 08, 2012 8:45 am
Site Admin
One thing that isn't clear for that auction is the type of L/R band. The last A904 I pulled out of a jeep case had the V8 band, which will not work in the slant six case.
Not a big deal, but you'd end up needing one more part. When you go after your filter, get a nice clean picture of the rear band and all that connects it to the servo. (Or perhaps an Australian transmission guru can verify which band is used.)
CJ
 Post subject: .
PostPosted: Sun Apr 08, 2012 8:49 pm
What gears does your trans slip in? All forward?,just one ?
