| Low deck 198? https://slantsix.org/forum/viewtopic.php?t=48476 |
| Author: | nuttyprof [ Tue Apr 10, 2012 7:40 am ] |
| Post subject: | Low deck 198? |
How hard would it be to put a 198 crank in a 170 block? What machine work for the block/crank? Which rods? Pistons? |
| Author: | slantvaliant [ Tue Apr 10, 2012 8:01 am ] |
Doc did one THIS WAY. With boring, it came out to 210 CID. Sounds like a good approach. Not sure about the availability of Vega pistons these days, though. |
| Author: | Doc [ Tue Apr 10, 2012 9:07 am ] |
http://www.slantsix.org/articles/stroking/stroking.htm You can use 2.2 pistons or the Wisecos instead of the Vega units. Fact is, we put a turbo on that engine and doing that quickly broke the skirts off those cast Vega pistons. (darn Chebby's and their broken piston skirts We replaced those pistons with some Buick V6 "slugs" with-out "slipper-skirts". The 210 is back together.... waiting for a car to go into. Anyway... the front and rear crankshaft counter-weights tend to hit the bottoms of #1 & 6 pistons so some engine "mock-up" work, measuring, then crank machining & rebalancing is required with the low block 198 build-up. DD ![]()
| Author: | nuttyprof [ Tue Apr 10, 2012 5:50 pm ] |
Would I use the 170 rods or another rod with pistons that have a lower compression height? Thanks Nuttyprof |
| Author: | ceej [ Tue Apr 10, 2012 8:07 pm ] |
You have to use the 5.7" low deck rods. I have a 210 "Kit" I bought from Josh some time back. I'm hoping to get something done with it next year. CJ |
