Speedometer?
https://slantsix.org/forum/viewtopic.php?t=48480
Author:  Shrug64 [ Tue Apr 10, 2012 1:09 pm ]
Post subject:  Speedometer?
OK, here is a question. The drivetrain out of my 52 Chrsyler is a 318 and matching tranny from an 89 Dodge Diplomat (I think it is a torqueflite).
Is there a way to hook the old speedo to the new tranny?
Thanks!
Tony
Author:  Doc [ Tue Apr 10, 2012 1:18 pm ]
There are a number of companies that will make you a custom speedometer cable but you will need to give them the end type & length.
Here is one webpage that shows a lot of the needed parts & options:
http://www.texasindustrialelectric.com/speedo.asp
Author:  SlantSixDan [ Tue Apr 10, 2012 1:42 pm ]
Very likely a '66-'67 full-size Dodge passenger car speedo cable will do exactly what you need.
Author:  Shrug64 [ Wed Apr 11, 2012 6:54 am ]
Thanks Dan. I will head over to NAPA this weekend and grab one. I will let you know if it works.
Author:  bigslant6fan [ Fri Apr 13, 2012 12:33 pm ]
Post subject:  .
In addition to the speedo cable Dan mentioned,you might need a different speedo gear adapter since the trans is from an '89 car. You can find it in '67-mid 70s cars and '67-late 80s trucks.
