| pilot bearing trouble https://slantsix.org/forum/viewtopic.php?t=48484 |
| Author: | swinger2013 [ Tue Apr 10, 2012 2:19 pm ] |
| Post subject: | pilot bearing trouble |
I'm having trouble installing the pilot bearing in my 74 slant six was orig an auto converting to 4 speed, it seems to be machined for the pilot bearing the bearing seemed to be a tad bit bigger than needed to go in smoothly.plz help[/b] |
| Author: | bigslant6fan [ Tue Apr 10, 2012 3:48 pm ] |
| Post subject: | . |
You're right, 73-up cranks are'nt final machined for the pilot bushing,if they were used behind an auto trans. You have two options: 1, use a late model magnum pilot bushing that presses into the larger crank pilot for the torque converter. or 2, try NAPA p/n 615-1033 that has a 0.914 OD |
| Author: | swinger2013 [ Tue Apr 10, 2012 3:54 pm ] |
so what do i need to do |
| Author: | bigslant6fan [ Tue Apr 10, 2012 4:02 pm ] |
| Post subject: | . |
I just edited my post with a p/n after you replied,sorry about that. Maybe you can google Mopar action magazine june 1999 for the full articule. |
| Author: | DusterIdiot [ Tue Apr 10, 2012 6:13 pm ] |
| Post subject: | Kind of... |
Quote: You're right, 73-up cranks are'nt final machined for the pilot bushing,if they were used behind an auto trans. You have two options: 1, use a late model magnum pilot bushing that presses into the larger crank pilot for the torque converter. or 2, try NAPA p/n 615-1033 that has a 0.914 OD
Mostly the really late ones are that way, most of the forged crank units I've seen from 73-75 were good. The 1976+ cast crank for an automatic is a 90% unfinished bore and requires the NAPA bushing installed with some loctite or will require you to get a roller bearing for a Dakota pickup to put in the crank pocket.-D.Idiot |
| Author: | swinger2013 [ Tue Apr 10, 2012 6:32 pm ] |
thanks for the help |
