| Timing... https://slantsix.org/forum/viewtopic.php?t=48509 |
| Author: | Shrug64 [ Thu Apr 12, 2012 11:14 am ] |
| Post subject: | Timing... |
OK here is a question (actually on a Dodge 318), how do I set the timing if I can not find a timing mark on the harmonic balancer? Is it possible that the timing is so far off that I am not seeing the mark? |
| Author: | hantayo13 [ Thu Apr 12, 2012 11:42 am ] |
balancer has slipped on inner rubber ring....need to find top dead center and remark,,,,,,not to say it wont slip some more ...better yet replace it |
| Author: | Shrug64 [ Thu Apr 12, 2012 5:24 pm ] |
I was afraid of that. Guess I will order up a new one. Luckily the engine is late model so it is easy to find parts. |
| Author: | 63gtcv [ Sun Apr 22, 2012 6:37 pm ] |
Fliud Damper |
| Author: | CNC-Dude [ Sun Apr 22, 2012 7:47 pm ] |
It also could have jumped time because of worn timing set. |
| Author: | Shrug64 [ Sun Apr 22, 2012 8:47 pm ] |
Well it turns out that my wires are not in the right positions. Problem is I can not identify number one on the distributor. I am going to have to try get the motor to TDC (always an iffy task) and go from there. |
| Author: | CNC-Dude [ Sun Apr 22, 2012 9:02 pm ] |
Well, at least you found the problem. |
