| Gasket sets/brands https://slantsix.org/forum/viewtopic.php?t=48539 |
| Author: | kipamore [ Sat Apr 14, 2012 7:21 pm ] |
| Post subject: | Gasket sets/brands |
I have my engine on the stand, and I am mixing/matching various parts from various engine. I want to buy a gasket set, though I probably won't need all of them. Slant Six Dan will know this one in two seconds: what's the best gasket set brand and where to get it? RockAuto, which has always done ok by me, shows two Fel-Pro sets, 2 Reinz sets, and 1 Sealed Power set. All the info and pics with each set are incredibly unhelpful. Any tips, oh Great Bearded Guru? -Kip-on-Truckin' |
| Author: | kielbasa [ Sat Apr 14, 2012 8:46 pm ] |
i used everything on my new motor from felpro, except for the aussi manifold gasket i had ordered from a member here. and also a remflex "hotbox" manifold to manifold gasket from another member. ive read that some oil pumps use a different shaped gasket then the felpro (felpro needing to be modified) but i had no problems with that with my melling oil pump. also i have read that some like a composite style oil pan gasket, which is harder, and wont squish like a cork, and also some said to have never used the 2 rubber end oil pan seals, and only used a large bead of silicone. |
| Author: | DadTruck [ Sun Apr 15, 2012 7:54 am ] |
I purchased a Fel-Pro 260-1038 for 81-87 slants set from ebay,, vendor was Falconglobal, for 54.98 included shipping. after delivery I went through the gasket set, noticed that one of the rear seal L gaskets was missing. Through e bay I sent a note to the vendor, they got back to me the next day,,apologizing for any inconvenience and sent to me a complete rear seal gasket set. |
| Author: | Aggressive Ted [ Sun Apr 15, 2012 9:30 am ] |
I run a combination of FelPro and RemFlex. Remflex on the exhaust pipe, intake and hotbox. The FlePro's just don't last long in those 3 areas when the surfaces are not freshly milled. |
