| Quick carb question - Holley 1920 3069 for 3054? https://slantsix.org/forum/viewtopic.php?t=48562 |
Page 1 of 2 |
| Author: | Chetterhead [ Tue Apr 17, 2012 11:30 am ] |
| Post subject: | Quick carb question - Holley 1920 3069 for 3054? |
After finding a nice hairline in my carb base, I'm in the market for a new one and have found a 1920 that either came off a 65 Dart or Valiant 170. The list on it is 3054 (from pictures it's hard to tell, but it's either a 4 or a 9 on the end). Will it swap out ok for my 1920 List 3069? The other number on it is 2468757. It's $80 and I'm willing to drive the hour to pick it up. Will it work? |
| Author: | Chetterhead [ Tue Apr 17, 2012 2:03 pm ] |
I just got pictures of the carb and the only differences seem to be in the choke linkage where I have a link and it seems to have a one piece metal tab that controls the dashpot, and the port where my PCV is hooked up is missing, but the port on the opposite side is open, whereas it's plugged on mine. |
| Author: | matv91 [ Tue Apr 17, 2012 6:05 pm ] |
From Holley Illustrated parts and specs book. 3054-1965 Dart and Valiant 170 engine 3059-1965 Dodge and plymouth 225 engine 3069-not listed. Under and left from fuel inlet,above casting number may be the venturi size 1-1/4 or 1-5/16. |
| Author: | Chetterhead [ Thu Apr 19, 2012 9:58 am ] |
I'm not really sure what this tells me, but I do know that it's 3069 (4712 below it) and the venturi size is 1 5/16. I'm going to tell this guy today that I can't use it. Which I'm guessing is the case. |
| Author: | SlantSixDan [ Thu Apr 19, 2012 10:28 am ] |
Don't see why you couldn't, if it's in good shape, but that sounds like a big "if". |
| Author: | Chetterhead [ Thu Apr 19, 2012 10:36 am ] |
What about the different position of the port? Is it the same port that goes to the pcv, just on the other side? It seems like everything should match up, it just has a different way of working, right? Considering that my cracked carb is killing me on turns, I'd be willing to take the gamble if I knew it'd at least fit. |
| Author: | Chetterhead [ Thu Apr 19, 2012 10:38 am ] |
Oh, I also just got the walker rebuild kit for my cracked carb. Would that work on this other one, or did I just become a victim of bad timing? |
| Author: | SlantSixDan [ Thu Apr 19, 2012 10:47 am ] |
Same kit. You'll want a new float, too. |
| Author: | Chetterhead [ Thu Apr 19, 2012 11:02 am ] |
Dan, you're officially my favorite person this whole month and possibly my car's favorite, period. I'm going to get it this weekend and I'll tell you how it goes! Or... you know, cry. |
| Author: | SlantSixDan [ Thu Apr 19, 2012 2:33 pm ] |
Quote: What about the different position of the port? Is it the same port that goes to the pcv, just on the other side?
Yup. Original PCV port location was at left front corner. First slant-6 carburetor to have it in the ~middle of the passenger side was the 1963-only Stromberg WA. By '70 they all had it on the passenger side.Quote: It seems like everything should match up, it just has a different way of working, right?
Assuming the carb is in basically sound shape, yes.
| Author: | matv91 [ Thu Apr 19, 2012 8:48 pm ] |
From Holley Illustrated parts and specs book. List no. 4712 Service replacement new carb. Fits 1960-69 chrysler product ,170 and 225 eng. All trans. Well thats what the book says. Too many years, should be throttle linkage change at some year? |
| Author: | SlantSixDan [ Fri Apr 20, 2012 9:19 am ] |
Not too many years, no. That carb has a throttle lever that accepts either the rod or the cable hookup. |
| Author: | Chetterhead [ Fri Apr 20, 2012 11:40 am ] |
Seriously Dan, my car would be in a bad way if it hadn't been for your advice on everything here. You rule!! |
| Author: | SlantSixDan [ Fri Apr 20, 2012 12:03 pm ] |
I am glad to help out. |
| Author: | Chetterhead [ Sun Apr 22, 2012 12:18 pm ] |
Hey, I've got a question for you Dan... When I was fiddling around with my existing carb, I found a bit of gummy stuff in the hole for the crankcase vent and I was wondering if you had any ideas as to where that might've come from. It seemed like glue or something. Clearish. Very flimsy. I'm wondering if one of the POs tried to block the passage. I thought I'd run it by you and see if you might know of some circumstance where something might've melted or degraded and leaked in there or a GOOD reason why someone would put gummy glue in there. ?? |
| Page 1 of 2 | All times are UTC-07:00 |
