It is currently Sun Jun 07, 2026 10:38 am
PostPosted: Tue Apr 24, 2012 6:43 pm
Changing trans and rear diff fluid and wanted to make sure I am putting the right amount back in. I looked it up in my fsm and it says the trans holds 3 1/4 pts and the rear 4 pts. I drained both and they had both had more in them than what the manual says. I'm sure both were changed by the previous owner so I'm not sure if he filled it until it came out the fill hole or what. Somehow the rear diff was filled above the plug on the side of the case.
Thanks
PostPosted: Tue Apr 24, 2012 6:58 pm
Thanks
He may have jacked the side of the fill hole up in air to fill it hence the over fill situation... and same for trans if it was over filled.... Just a SWAG tho...
MRO....
PostPosted: Wed Apr 25, 2012 5:27 am
I usally fill till it starts to run out the fill hole
PostPosted: Wed Apr 25, 2012 5:43 am
The rear is about 1/2" below the fill plug and the trans is about 3/4-1" below. I added what the FSM said and in the case of the rear I sucked out the old fluid so I'm sure I did not get all the old out so I would think there would be 1/4-1/2 qt of extra fluid in it. I just want to make sure I have enough in so I don't damage anything.
Thanks
PostPosted: Wed Apr 25, 2012 8:01 am
there are drain plugs on bottom of both
PostPosted: Wed Apr 25, 2012 10:12 am
I have a drain plug in the bottom of my trans but did not see one in the botom of the 8 3/4.
PostPosted: Wed Apr 25, 2012 10:21 am
You are correct in that there's no drain plug on the 8.75. There's a thread around here or over at FABO about retro fitting a drain plug into the bottom of the 8.75 if you choose to do that.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
Users browsing this forum: Killer6 and 3 guests
