| 64 dart, replacement for Kermit. https://slantsix.org/forum/viewtopic.php?t=48607 |
| Author: | bbbmmm [ Mon Apr 23, 2012 12:00 am ] |
| Post subject: | 64 dart, replacement for Kermit. |
I finally have the engine cleaned up and painted. New Holley 1945 carb, 75' 225 with 64' sheet metal. I plan to modify the air cleaner base to accept the early model air cleaner top. The radiator has been done and the transmission rebuilt. I also have a Scarebird disc brake kit going in after the engine runs and I get to have some fun driving it. The brakes work for now so I plan to do the disc conversion in a couple of months. If I feel that the power is lacking I may install a new Carter BBD that I have around. I don't understand the amount of time people waste on old crappy carbs, I buy new or NOS whenever the budget allows. Photo's later when I have more time. |
| Author: | bbbmmm [ Mon Apr 23, 2012 6:46 am ] |
| Author: | bbbmmm [ Mon Apr 23, 2012 8:47 am ] |
One more try on the photo's. ![]() 75' motor with 64' sheet metal, MOPAR industrial red. Holley 1945 (new). ![]() ![]() All cleaned up and ready to go.
| Author: | Fopar [ Mon Apr 23, 2012 8:49 am ] |
That looks very nice Richard |
| Author: | THOR [ Mon Apr 23, 2012 1:26 pm ] |
If you are not going to run A/C, I would recommend taking off that fan and installing a standard 4 blade piece. That fan you have will take alot of power to spin. Other than that, it looks GREAT! ~THOR~ |
| Author: | bbbmmm [ Mon Apr 23, 2012 4:39 pm ] |
I'm in Phoenix, AC will be installed in this car. Thanks for the complement , I really like the contrast of the red and white. |
| Author: | hantayo13 [ Mon Apr 23, 2012 4:46 pm ] |
Where did you find that there fancy aircleaner????? looking good keep on roddin' |
| Author: | slantvaliant [ Wed Apr 25, 2012 2:17 pm ] |
Quote: Where did you find that there fancy aircleaner????? looking good
That's to keep the NSA from reading the Slant's brainwaves.
| Author: | bbbmmm [ Wed Apr 25, 2012 9:27 pm ] |
Quote: That's to keep the NSA from reading the Slant's brainwaves.
That was the plan, I may have to go to plan "B" now that my secret is out.
| Author: | wjajr [ Thu Apr 26, 2012 6:28 am ] |
Not new, but time tested. |
| Author: | bbbmmm [ Sat Apr 28, 2012 9:53 pm ] |
Progress, engine installed. Transmission too, one small holdup is the speedometer pinion seal. The only source that I know of is Torqueflite Patty. Unless I find another source I will order his seals tomorrow. Napa says that they have it but it is the later seal. ![]() ![]() I made up a new air cleaner based on the centurion model. ![]() I had trouble getting the radiator in with the big fan. Four blade going in with an electric fan assist for the AC. Probably better anyways. Is a quarter inch enough clearance between the fan and radiator?
| Author: | AussiePlymouths [ Wed May 30, 2012 10:37 pm ] |
| Post subject: | Great project |
Gees brian, that's a great job that you're doing there - Kermit would be proud of ya! Sorry I'm not clued up on the fan clearance so maybe you should shoot a PM to Dan? It's a great thread, any more pics available since your last post? Congratulations on some good work. Regards Gary |
