It is currently Sun Nov 22, 2026 12:56 am
PostPosted: Wed May 02, 2012 4:58 pm
Car Model: 1964 Dart 270
I read this in other posts on overheating but need a quick update what size thermostat is reccommended and does the spring side go in the head........thanks
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Wed May 02, 2012 5:25 pm
I'd say a 180-195, and yes..
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Wed May 02, 2012 5:29 pm
I concur with the above statement!
PostPosted: Wed May 02, 2012 5:35 pm
Ok thanks it had a 160 in it, but after the reading on overheating I wanted to go with a reccommended 180-195.......Thanks
PostPosted: Wed May 02, 2012 6:02 pm
"180-195" doesn't mean anything. That's two different thermostat temperatures.
180° is the correct and optimal choice. Preferably Stant SuperStat #45358. You can use a 195° thermostat, but it will tend to cause and/or aggravate hot-start/hot-idle issues -- this is the reality of running yesterday's car on today's gasoline. 160° or no thermostat at all is never the correct choice.
PostPosted: Wed May 02, 2012 7:22 pm
Thanks for clarifying that Dan...........
PostPosted: Thu May 03, 2012 9:51 am
if i am running a 195 because of simple ignorance, could that cause overheating at highway speed? just wondering if i tried to fix the problem with mine the wrong way.
-Christopher
"Gray Ghost"-1970 Dart.
"Frederick II"-1994 Geo Metro.
PostPosted: Thu May 03, 2012 10:35 am
I run 195s in my cars. It should not cause overheating on the hwy. Check that your gauge is not just reading high too.
Mileage will generally be better w/a 195, but as Dan said you can have hot starting issues.
PostPosted: Thu May 03, 2012 10:39 am
No.
PostPosted: Thu May 03, 2012 4:24 pm
Installed a 180 degree thermostat, the Stant Dan suggested. So far so good seems to operate better then the 160 degree.......again thanks for all the responses and help.
Users browsing this forum: DuckDuckGo [Bot] and 17 guests
