It is currently Wed May 27, 2026 6:44 pm
 Post subject: 9" drum hub question
PostPosted: Mon Jun 04, 2012 6:27 pm
Car Model: 87 B150, 1970 Valiant 4-door
Will my 1970 9" drum hub work with the K-H 4-piston rotors?
PostPosted: Mon Jun 04, 2012 6:32 pm
No. :(
PostPosted: Mon Jun 04, 2012 6:47 pm
Thanks.
I stupidly thought that the only parts I couldn't buy new or rebuilt (yeah, I know...) for the conversion were the spindles and dust shields.
I recently read the FSM and realized that the rotors are the kind that attach to separate hubs.
So I guess I am now in the market for junkyard hubs & spindles, minimally--and maybe dust shields
Are there aftermarket dust shields?
I assume someone must sell plastic or aluminum versions for racing.
PostPosted: Tue Jun 05, 2012 4:17 pm
This is a link for using much more common and aftermarket supported early mustang sourced KH rotors on an a-body. The main advantage is you can retain your spindle/knuckle/UCA and convert to 4.5 bolt pattern disc brakes. Off course the rear end would still be 5X4" but I just wanted to put some info out there.
http://www.forabodiesonly.com/mopar/sho ... hp?t=20544
PostPosted: Wed Jun 13, 2012 7:16 pm
Well I wouldn't be retaining my spindles as they are for 9" drums, and I (moreover my wife, who's car it is) likes the stock rims.
I'm converting to KH 4-piston and retaining the bolt circle.
I'm just trying to glean what all I need to source used before I start buying new parts.
