It is currently Sun Nov 29, 2026 6:37 am
PostPosted: Thu Jun 20, 2013 1:54 am
Trying to figure out what kind of an oil pump I bought from jhdeval (thanks). Looked everywhere for the familiar CDPD logo, but couldn't locate any. This almost seems like maybe an early-design Melling. It has 6 bolt holes, plus the cover plate is similar to the later-model MoPar-designed softly-rounded kidney plate, more-so than the sharper-edged-kidneys currently-available on Melling repop's.
The pump body is cast iron (heavier than my aluminum bodied original flat-cover plate MoPar pump that I destroyed, trying to remove). At first the rotor was stuck but after removing a good amount of gunk, it started to turn. But not a complete revolution: there was a hiccup. Had to remove the cover. Realized this pump last circulated oil with some water content in it, because some of the pump internals were slightly rusty, see the pics.
So again, question 1) what kind of pump is this? I'm aware Melling makes 5-bolt hole pumps with non-hardened gears, but this isn't one of those, unless it's an early Melling. #2) How do I know I have a hardened gear on this thing? Jhdeval thought so: how can I tell for sure? See pics.
Also, take a look at the pictures of the rotor, impeller and cover plate. Rotor and cover plate have wear: wondering if either will cause me problems.... Pictures below.
BEFORE
AFTER
PostPosted: Thu Jun 20, 2013 3:19 am
No pumps come with hardened gears from the factory. If it has one then someone put it on later and it came from Doc,
Rick
 Post subject: It's...
PostPosted: Thu Jun 20, 2013 7:17 am
The stamp on the oil filter gusset says it all "M66", that a replacement pump from Melling the 7/8" thick rotor version. If it pumped oil, it should be good, i don't see major scoring or checks in the rotor ring per your picture. Wear pattern on the gear is right down the middle and good there but the gear is soft. Six bolts either means it's an early one, or someone took it on themselves to drill the 6th bolt holes.
This is true, but the factory pumps came with harder gears than the new melling pumps, so if in a pinch, you can swap the gear off your old beat up OEM pump onto the new Melling and it should be good to go.
PostPosted: Thu Jun 20, 2013 7:37 am
I apologize I think there was some confused information I read. I understood that the metal gears were hardened. If you are not satisfied with the Pump I will certainly take it back.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Thu Jun 20, 2013 7:58 am
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
My Melling pumps have M66 on them so..that!!
It would be cool if you could get aluminum bodied pump!!
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
 Post subject: You need...
PostPosted: Thu Jun 20, 2013 8:29 am
The 80's truck OEM Oil pumps are aluminum bodied (the rotor and ring are the heaviest parts on them). The only draw back to these is the casting, so far I've thrown 3 of them out because the bypass/pressure relief piston bores seem to get the worst pitting and corrosion and it's nary impossible to try and recondition the passage so the piston will slide smoothly through the bore again (a dowel and sand paper isn't enough).
