| No love for manifold studs... https://slantsix.org/forum/viewtopic.php?t=48651 |
Page 1 of 2 |
| Author: | Red [ Thu Apr 26, 2012 4:43 pm ] |
| Post subject: | No love for manifold studs... |
Oh well: I guess 11 out of 13 ain't bad. Got eleven of them out with much coaxing, copious repeated applications of Tri-Flow, a stud remover and a propane torch (MIG I got, but no gas rig). Any guesses as to which ones were the hold-outs? Yes, indeed: the notorious end ones. One was already broken off when I snagged the head at the boneyard and the other I broke (despite being reasonably patient and careful). So far, I'm having no luck geting the broken ones out with easy-outs: the suckers are pretty much "rust-welded". Might be drill/Heli-Coil time. The nipples up by the thermostat housing are also being pretty stubborn. Seems like 8 of the manifold stud holes on this head penetrate the water jacket. I got curious and poked around with an ice pick after finding significant rust on the ends of several of the studs. I thought that consensus was that only the end studs penetrated the water jacket...or does it just vary, head-to-head according to core shift and all? |
| Author: | Rick Covalt [ Thu Apr 26, 2012 5:46 pm ] |
| Post subject: | stud |
I have drilled a starter hole (1/8") and kept increasing the size until I could get what was left of the stud out. You just have to be sure you are pretty close to center of the stud. Use a little heat on it and a pick and you can usually "fish" the threads clean. You can do it on the car but it is easier if the head is off. Rick |
| Author: | 65Dodge100 [ Thu Apr 26, 2012 6:00 pm ] |
You may have already tried but I've had some luck heating the drilled stud and the area around it as red as I can get it without melting anything. Let it cool then try the EZ-Out. It burns out the rust or the piece of stud shrinks faster - I don't really know but it's worked a lot of times. Do not try the EZ -Out while it is cherry red. I've had it work before but it's very unpredictable. It can break the EZ-Out with no pressure at all or turn right out. I guess it depends if you are using a 3/4" EZ-Out or a little tiny one for 5/16" studs. If all that failed, I'd try the drill it all out and re-tap. A size "F" drill will take everything out except the threads if your hole is centered. An "F" letter drill is 0.257 dia. A 1/4" drill (0.250) would be very close if you don't have a letter drill set. Then very carefully tap the hole with a 5/16" tap. It's tricky and doesn't work sometimes. The threads from the old bolt spin a little and lock up the tap. You do not want to break the tap in the hole but they are usually pretty easy to "bust up" with a punch so you take it out in pieces. If you have a very fine pointed pick you might be able to pick out the threads instead of using the tap. I didn't poke around to find out how many of my holes went into water but I know it was more than 2 or 3. Maybe all of the bottom ones go into the water jacket. Danny |
| Author: | DadTruck [ Thu Apr 26, 2012 6:00 pm ] |
Red the complete top row and most of the bottom row of manifold stud holes on the head for the 83 D-150 are drilled completely through into the water jacket,, found that out as the replacement studs that I am using are fully threaded with with a coarse 3/8 thread,, they would would continue to run in,, till they ran into a head bolt boss or something way inside the water jacket...that would leave about a 1/4 of the stud outside the manifold face... fixed it by using a chisel to put a real good wrinkle in the thread at the depth for normal engagement... and coated the stud threads with a coating of the bronze colored RTV prior to running them in,, as far as getting the stuck one out,, can you get it under a drill press and drill it? regards DT |
| Author: | Red [ Thu Apr 26, 2012 6:34 pm ] |
Thanks, Rick: sounds like a good approach which I will try tomorrow. I've already drilled all the way through the broken off studs and really don't want to break off an easy-out in there (been there, done that before). ____________________ John and Danny, "the complete top row of manifold stud holes on the head for the 83 D-150 are drilled completely through into the water jacket" FWIW, the head I'm working on is a 2843169, "plug-tube" casting, which should date it somewhere from '68-'75, if I'm not mistaken. If the stud breaks had left me some stubs, I would've tried the "weld-on-a washer-and-nut" trick, but they are both broken off below the surface. When I said "11 out 0f 13 ain't bad" I was actually serious. When you consider how many decades the studs have been in there, I'm surprised I didn't snap off a couple more. Below is the stud remover I used. Works quite well as long as you keep the base of the tool flush against the block (to avoid side-loading the stud as you turn it). With such dainty studs, really is a fine line between breaking them loose and twisting them off. Oh well, we'll get there...
| Author: | DusterIdiot [ Thu Apr 26, 2012 7:10 pm ] |
| Post subject: | Round 2 |
You should center drill them with a 1/8" cobalt bit then see if a reverse twist drill bit will grab and take them out. If not you'll need a couple more cobalt drill bits and a 5/16" thread tap. -D.Idiot |
| Author: | Red [ Thu Apr 26, 2012 7:27 pm ] |
Thanks, DI: something else to try. Tried an appropriately-sized one of these in a tap handle (after more torching) this afternoon...alas without success. It "bit" into the stud, but I was afraid of snapping it off if I applied too much torque:
| Author: | emsvitil [ Thu Apr 26, 2012 7:41 pm ] |
A dremel and small carbide bit to grind the stud out (if it broke flush)... Time consuming, but you won't break an easy out......... |
| Author: | SlantSixDan [ Thu Apr 26, 2012 11:44 pm ] |
You don't need a Heli-Coil; see here. |
| Author: | Mroldfart2u [ Fri Apr 27, 2012 6:01 am ] |
| Post subject: | Re: Round 2 |
Quote: You should center drill them with a 1/8" cobalt bit then see if a reverse twist drill bit will grab and take them out. If not you'll need a couple more cobalt drill bits and a 5/16" thread tap.
Thats what I have always had the best luck using... heat from the drilling AND the reverse rotation is usually enough to get it to spin out...
-D.Idiot |
| Author: | Red [ Fri Apr 27, 2012 7:43 am ] |
That DOES sound like a better solution than a Heli-Coil, Dan. Thanks. |
| Author: | Red [ Sun Apr 29, 2012 10:14 am ] |
Got the end stud holes all cleaned out. This thing helped keep the drill running true/perpendicular: ![]() ![]() I bought this device back during the '70s and the company has since gone belly up. You can still find them around, though. IMHO, they are superior to a similar item (currently manufactured by another company) which allows for angle-adjustment of the base, but doesn't stay locked into a given angle very well. |
| Author: | kielbasa [ Sun Apr 29, 2012 12:17 pm ] |
i never had luck with those stupid stud removers, best tool you can invest in, are the matco stud removers. i have a set for metric, and std. very bitchen stuff. and they work as installers as well. |
| Author: | Rug_Trucker [ Sun Apr 29, 2012 7:25 pm ] |
I've take them to the machine shop. How it comes out? I could care less. Their charge is less than my time. Acetelyne warms thing up a bunch faster than propane. |
| Author: | emsvitil [ Sun Apr 29, 2012 7:27 pm ] |
I've got one of those............ but don't have the box. Quote: Got the end stud holes all cleaned out. This thing helped keep the drill running true/perpendicular:
| Page 1 of 2 | All times are UTC-07:00 |
