It is currently Sat Jun 06, 2026 8:05 am
 Post subject: 7.25 axle gasket
PostPosted: Fri Apr 27, 2012 9:56 pm
Car Model: 1964 Dart 270
Where is a good place to get a axle gasket for my 64 Dart GT 7.25 axle? Does it have a drain plug or the cover being removed is the way to drain it?
PostPosted: Fri Apr 27, 2012 11:04 pm
Fel Pro part # RDS12775 should be able to get it through your preferred local parts store.
No drain plug, just pop the cover off. If the fill plug looks like it takes a really funky male star type socket, it's probably just a 3/8" or 1/2" drive from your ratchet. Hope that helps.
PostPosted: Fri Apr 27, 2012 11:07 pm
Sure does thanks very much.........
PostPosted: Sun Apr 29, 2012 6:52 am
Yep, a 1/2" drive rachet will loosen/tighten that filler plug.
PostPosted: Sun Apr 29, 2012 9:14 am
Thanks for all the help, got a gasket ordered. Plan to change fluid this week..........
