7.25 axle gasket
https://slantsix.org/forum/viewtopic.php?t=48658
Page 1 of 1
Author:  64DartGT [ Fri Apr 27, 2012 9:56 pm ]
Post subject:  7.25 axle gasket
Where is a good place to get a axle gasket for my 64 Dart GT 7.25 axle? Does it have a drain plug or the cover being removed is the way to drain it?
Author:  zorg [ Fri Apr 27, 2012 11:04 pm ]
Fel Pro part # RDS12775 should be able to get it through your preferred local parts store.
No drain plug, just pop the cover off. If the fill plug looks like it takes a really funky male star type socket, it's probably just a 3/8" or 1/2" drive from your ratchet. Hope that helps.
Author:  64DartGT [ Fri Apr 27, 2012 11:07 pm ]
Sure does thanks very much.........
Author:  roadrunnerh [ Sun Apr 29, 2012 6:52 am ]
Yep, a 1/2" drive rachet will loosen/tighten that filler plug.
Author:  64DartGT [ Sun Apr 29, 2012 9:14 am ]
Thanks for all the help, got a gasket ordered. Plan to change fluid this week..........
