| V8 Rear End Brake Question https://slantsix.org/forum/viewtopic.php?t=48673 |
| Author: | 63Valiant [ Sun Apr 29, 2012 7:56 pm ] |
| Post subject: | V8 Rear End Brake Question |
I've had a V8 rear end in my '63 for many moons now. The larger brakes do not pose a problem with normal braking, but when a woman driver cause me to use moderate to heavy braking that rear end locks up real fast. I've read here that you can use a smaller wheel cylinder to re-sync the brake system, but I haven't found which wheel cylinder to use. Does someone know which ones I need? TIA! (Still have the stock drum brakes, single master, no booster.) |
| Author: | SlantSixDan [ Sun Apr 29, 2012 8:54 pm ] |
Smaller front brakes than rear ones isn't a safe situation; please make plans to upgrade the front brakes ASAP. For now, the wheel cylinders you want are NAPA-United 37696, Raybestos WC37696, Wagner F113704, or ACDelco 18E268 is the wheel cylinder you want — times two (left = right). |
| Author: | 63Valiant [ Mon Apr 30, 2012 6:19 am ] |
Awesome, thanks again Dan! |
