Clutch Fork for 833OD
https://slantsix.org/forum/viewtopic.php?t=48688
Author:  husker1 [ Mon Apr 30, 2012 8:08 pm ]
Post subject:  Clutch Fork for 833OD
Can a 3sp clutch fork be used in a 4 speed od bellhousing? I have purchased 4spd od bellhousing that did not come with the fork and was wondering if a 3spd one will work or be modified to work.
Thanks
Author:  DusterIdiot [ Mon Apr 30, 2012 8:17 pm ]
Post subject:  As long as...
It's from the same type of car...The fork from my 1974 A-230 is the same as the forks from all the 1975-1980 A/F body A833OD's...It will get kind of hinky if you try to use an early '60's fork.
Author:  husker1 [ Tue May 01, 2012 5:25 am ]
Hinky you say, I'll try to avoid that! I have a '71 D100 3spd, do you think that one will work? I am replacing the 3spd with the 4sp od.
Thanks
