It is currently Thu Nov 26, 2026 12:17 pm
PostPosted: Mon May 14, 2012 8:31 pm
A new exhaust manifold that I have recently picked does not have the same vacuum tube as my old one. This vacuum tube was connected to the throttle body on on the BBS. Is this needed? Does it effect the high speed circuit or? I have everything reassembled and running with a plug in the throttle body to seal the vacuum leak. Thoughts...what am I missing? :?
Thanks
Slant On!
1968 Coronet
PostPosted: Mon May 14, 2012 8:53 pm
I'll add this... 1968 Coronet Sedan/Taxi Canadian. Any other info needed? Just let me know.
Slant On!
1968 Coronet
PostPosted: Tue May 15, 2012 9:55 am
"Canadian" is the key. See here. With today's gasoline formulations this system is no longer needed, and it causes (or aggravates) hot start/hot idle issues. Put a brass adaptor fitting (invert-flare threaded x hose barb) in the carburetor port presently occupied by the metal pipe running from the exhaust manifold. Run the rubber hose directly from the fitting on the underside of the air cleaner to the new brass fitting.
PostPosted: Fri May 18, 2012 9:35 pm
As always.... you are the man, Dan! Thanks
Hope to see a response on my next "confused" post :!:
Slant On!
1968 Coronet
Users browsing this forum: Ahrefs [Bot] and 14 guests
