| Proper line size? https://slantsix.org/forum/viewtopic.php?t=48735 |
| Author: | 64DartGT [ Sat May 05, 2012 1:46 pm ] |
| Post subject: | Proper line size? |
What is the size of the line (Diameter) from the master cylinder to the proportioning valve on a 1964 Dodge Dart? And anyone knows the length you get to bend it out of? Thanks |
| Author: | ValiantBoyWonder [ Mon May 07, 2012 9:41 am ] |
i have a 70 and it was 3/16 line, you could get away with a foot or 16" if you put a loop in it. also, the master cylinder fitting is a bigger size than the 3/8 one it comes with. i'd suggest finding the right fitting and flaring (double) the line and doing it right. i bought mine at a local auto parts store (i ended up just buying the spool, $25 i believe). |
| Author: | 64DartGT [ Mon May 07, 2012 10:47 am ] |
Thanks for the info I need yo replace my master cylinder and want to replace the line they look.like the original parts and I want the replacement to look original ............ |
| Author: | Doc [ Mon May 07, 2012 11:53 am ] |
The "single pot" systems used a 1/4 tube size leading down to the metering block. Be careful with the fittings that come on pre-made hard lines these days, some of those do not fully seat in the fitting on the master cylinder. DD |
| Author: | 64DartGT [ Tue May 08, 2012 5:17 am ] |
Thanks tor the info about the single pot system that is it for sure ............... |
