| Offenhauser 2 1bbl setup https://slantsix.org/forum/viewtopic.php?t=48756 |
| Author: | '67 Dart 270 [ Tue May 08, 2012 2:18 pm ] |
| Post subject: | Offenhauser 2 1bbl setup |
I've decided to go with a dual 1BBL offy intake for my 225 (with Dutra Duals). Does anyone recommend the Holley 1920 or Carter BBS, one over the other? Does SlantSixDan or anyone, have matched set of either for sale? Thanks All, '67 Dart 270 |
| Author: | SlantSixDan [ Tue May 08, 2012 2:36 pm ] |
There's a case to be made for the 1920, the BBS, the 1945, the WA3, and other carbs on the Offy twin 1bbl setup. The most important thing is that the two carbs be exactly matched. Send me a PM and I'll see what I can dig up. Setup notes for the twin 1bbl are here. |
| Author: | kesteb [ Wed May 09, 2012 5:41 pm ] |
A pair of these http://stoveboltengineco.com/catalog/st ... ct=1222026 would be interesting. They sell them for the 235 chevy. |
| Author: | '67 Dart 270 [ Wed May 09, 2012 10:20 pm ] |
| Post subject: | dual carbs |
How did you find these? Is it $180 for the pair? Are they enough CFM's if they were intended for a 97 cu. in. engine? I'm intrigued for sure...I suppose they'd fit an offy manifold, even if I needed adapter plates... brian |
| Author: | '67 Dart 270 [ Wed May 09, 2012 10:28 pm ] |
For that price, it's almost a no brainer to try them... Might even be better than dual 1920's or BBS's.... |
| Author: | kesteb [ Sat May 12, 2012 10:07 am ] |
The carb pads on the Offy are more then big enough to drill for these carbs. No adapter needed. |
| Author: | '67 Dart 270 [ Sat May 12, 2012 12:32 pm ] |
| Post subject: | carbs |
..and these are progressive carbs, designed for a 98cc engine, so two of these would be perfect for a slant six. At low R's no issues with too rich a mixture and at higher R's, likely all one would need. Like a small four barrel but better flow with the dual offy...can't wait to set it up! BG |
| Author: | '67 Dart 270 [ Sat May 12, 2012 8:21 pm ] |
| Post subject: | kick down linkage |
Anyone know how to hook the kickdown linkage when using the offy manifold with two carbs? bg |
| Author: | Dart270 [ Sun May 13, 2012 4:03 am ] |
You either rig up a kickdown cable, or run w/o one and lock the KD lever back about 1/2-2/3 of the way. Lou |
| Author: | SlantSixDan [ Sun May 13, 2012 8:27 am ] |
Quote: You either rig up a kickdown cable, or run w/o one and lock the KD lever back about 1/2-2/3 of the way.
The latter suggestion is a good recipe for slow-cooked transmission, yum. Do the job completely and correctly. Working throttle pressure ("kickdown") linkage of some kind is necessary, whether it's a stock-like rod setup or a cable setup. See this thread for some aftermarket kickdown options.
| Author: | wvenable [ Sun May 13, 2012 8:29 am ] |
What is the cfm rating for these carbs (stovebolt webers) ? |
| Author: | '67 Dart 270 [ Mon May 14, 2012 2:23 pm ] |
| Post subject: | kickdown linkage |
Thanks so much, definitely want a complete and well done setup, I was just asking how others might have done the kick down. Thanks for link! BG |
| Author: | Doc [ Mon May 14, 2012 2:51 pm ] |
You run a rod thru the two posts, already casted into that intake, then make some pieces to connnect it to the trans KD lever. DD
