carb question
https://slantsix.org/forum/viewtopic.php?t=48809
Page 1 of 1
Author:  edward9egan [ Mon May 14, 2012 8:36 am ]
Post subject:  carb question
so i have 2 different gaskets for the carter bbd and i have no idea which one to use. one is a thick gasket with notches in the far ends. the other is a thin one with the notches on the long sides. it is going on a 1969 225 if that makes any difference for which one to use.
Author:  SlantSixDan [ Mon May 14, 2012 2:29 pm ]
Use the thick one.
Author:  edward9egan [ Mon May 14, 2012 6:44 pm ]
thanks for the info. what is there any reason for that
Author:  SlantSixDan [ Tue May 15, 2012 9:56 am ]
Heat insulation.
