trans pops into neutral when flooring it
https://slantsix.org/forum/viewtopic.php?t=48813
Page 1 of 1
Author:  Smokin Jays [ Mon May 14, 2012 8:47 pm ]
Post subject:  trans pops into neutral when flooring it
when I floor the car the trans slowly slips from drive to neutral. This ONLY happens when floored. It works fine if I gradually put the pedal all the way down but when I floor it it slips. Any suggestions on what the cause is?
Author:  Fopar [ Mon May 14, 2012 9:07 pm ]
Have you checked the kick down linkage adjustment, or is the linkage missing altogether??
Richard
Author:  Greg Ondayko [ Tue May 15, 2012 2:30 pm ]
Broken Trans or Motor Mounts is my guess..
The engine torque with broken mounts is moving the lever when you dont want it to.
Author:  Smokin Jays [ Tue May 15, 2012 10:56 pm ]
The linkage is there but might not be adjusted correctly. I tried to adjust it to what i think is correct but i am probably off. It is a 2 barrel set-up and some custom fab work was done. There is a new trans mount and the trans works and shifts great under normal driving conditions, but the kickdown is probably off as i am learning as i go on my car. I do have a custom converter with a 2400 stall maybe that is part of the problem? Or kickdown linkage.
Author:  THOR [ Wed May 16, 2012 4:18 pm ]
Set-up your kickdown so that when your throttle is wide open (read: full throttle) the linkage has pushed the arm on the transmission ALL THE WAY back. It should not be "tight", it should simply "stop" all the way back when the throttle is opened all the way.
If that is the case, then it sounds like you've got some internal transmission adjustments to make....
When was the last time the bands were adjusted?
~THOR~
Author:  slantzilla [ Wed May 16, 2012 6:51 pm ]
I'm with Ceej here.
IF the kickdown linkage is not binding on the shift linkage, motor mounts would be the obvious answer.
:D
Author:  Smokin Jays [ Wed May 16, 2012 9:48 pm ]
Motor mounts are a little worn. Thanks for the info! Will change them soon i know they are cheap!
Author:  Greg Ondayko [ Thu May 17, 2012 10:17 am ]
I'm with Ceej here.
:D
What are you talkin about.. i didnt see CJ chime in yet.. or am I loosin it?
Author:  Smokin Jays [ Thu May 17, 2012 12:27 pm ]
I have not adjusted the bands and i just put the trans in the car. I bought it used and slapped it in. I do see some cracking in the motor mounts as they are probably the originals.
Author:  slantzilla [ Thu May 17, 2012 2:50 pm ]
I'm with Ceej here.
:D
OOPS! That's what I get for posting when I should be sleeping. :oops:
Author:  Greg Ondayko [ Fri May 18, 2012 2:45 am ]
okay ha ha.. we all do that.. every now and then..
Now stop typing and get to work on your blue car with a slant 6 in it!
Author:  slantzilla [ Fri May 18, 2012 3:05 am ]
It's out in the garage and progress has been made. :lol:
