It is currently Thu Nov 26, 2026 3:33 pm
 Post subject: carb question
PostPosted: Mon May 14, 2012 8:36 am
so i have 2 different gaskets for the carter bbd and i have no idea which one to use. one is a thick gasket with notches in the far ends. the other is a thin one with the notches on the long sides. it is going on a 1969 225 if that makes any difference for which one to use.
1969 Dodge Dart
1975 Plymouth Duster
1970 Plymouth Valiant
PostPosted: Mon May 14, 2012 2:29 pm
Use the thick one.
PostPosted: Mon May 14, 2012 6:44 pm
thanks for the info. what is there any reason for that
1969 Dodge Dart
PostPosted: Tue May 15, 2012 9:56 am
Heat insulation.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 6 guests
