| Source for 7.25 Differential Side Bearing Cup Spacer Washers https://slantsix.org/forum/viewtopic.php?t=48820 |
| Author: | DonPal [ Wed May 16, 2012 5:34 pm ] |
| Post subject: | Source for 7.25 Differential Side Bearing Cup Spacer Washers |
The differential bearing preload spacer washers vary in thickness from .254 to .290 thick. They have an OD of about 2 7/8 & ID of 2 1/2. I need something on the order of .265 thick & another about .271 thick. Has anyone identified a source for these spacers since setting up the pinion/ring gear backlash depends on trying something close to what's required and then adjusting their size once again after checking tooth contact patterns? The spacer's I pulled out give too much ring gear/pinion backlash with the new bearings installed on the sure grip differential assembly. |
| Author: | Doc [ Thu May 17, 2012 10:29 am ] |
Send me a PM with your shipping address. DD
