| vin number location 1967 Dart ? https://slantsix.org/forum/viewtopic.php?t=48862 |
| Author: | USAJon [ Mon May 21, 2012 11:23 am ] |
| Post subject: | vin number location 1967 Dart ? |
so Im looking @ a 1967 Dart no vin on the driver's door jam car is tagged driven is the a vin anywhere else on this car that i can verify with the title? |
| Author: | Mroldfart2u [ Mon May 21, 2012 11:50 am ] |
Radiator support MAYBE??? Not for sure, but it will have another actually stamped in it somewhere... I am assuming you have your doubts about the actually VIN plate for wanting to verify? |
| Author: | USAJon [ Mon May 21, 2012 12:26 pm ] |
it's a pricey car and in Maryland they will impond without a vin you can get a reasement title but the hidden vin must match the title or they keep the vehicle as altered aka issues |
| Author: | DusterIdiot [ Mon May 21, 2012 7:29 pm ] |
| Post subject: | Some other ways to check the late A-body... |
Driver's door jamb is one. Some have a sticker on the driver's door edge. Fender Tag. Last 6 of VIN on top of Radiator mount. Same Last 6 can be found on certain years on the crossmember rail under the carpet under the backseat. -D.Idiot |
| Author: | ESP47 [ Mon May 28, 2012 3:52 pm ] |
When you open the door, you should see it by the door hinges between the door and fender. |
