| remflex hotbox gasket question (pics) https://slantsix.org/forum/viewtopic.php?t=48865 |
| Author: | kielbasa [ Mon May 21, 2012 8:51 pm ] |
| Post subject: | remflex hotbox gasket question (pics) |
so i finally got around to getting my exhaust manifold blasted, and painted up, ready for a mockup. i got my self the remflex setup, both heat riser, and manifold to head. anyways i started mocking up the 2 manifolds as per the article. attached the 2 manifolds with the hotbox gasket, with 3 bolts hand tight. then layed it down on the head, and started from the center out, just hardly snug at all. then went back to the 3 manifold/manifold bolts, and torqued them down to 22ftlbs. as the article states. i slowly torqued them, from 15, to 18, to 20, then 22. so i didnt tight one side too much. then i noticed that the ears of the gasket split, now im not sure if this is normal for this style of gasket (i never used a graphite gasket before), and is common, and people had no issues of running it as is, or should I tear it all back apart, and put a new gasket in place... but im sure it would just happen again. input?? thank you friends ![]() manifold is painted with a high temp cast iron color paint, i think it looks great.
| Author: | DusterIdiot [ Mon May 21, 2012 9:28 pm ] |
| Post subject: | I would... |
Leave it and run it. The important part is the gasket at the hotbox flanges, not the ears. -D.Idiot |
| Author: | kielbasa [ Mon May 21, 2012 9:59 pm ] |
i was just thinking maybe somehow the gasket would start to split all the way around, then burn out.. but i guess its good to go. now i just need to find a place to surface the manifolds flat. that seems to be the hard part. |
| Author: | SlantSixDan [ Mon May 21, 2012 9:59 pm ] |
Yup, it's normal and fine. |
| Author: | kielbasa [ Tue May 22, 2012 12:58 pm ] |
okay, i got another question, instead of starting new thread ill use this. with out any gasket at all, the largest gap i have is .016, between manifold and head. since im using the remflex gasket, which states it will fix 1/16" of gap, im just not sure if the 10ftlb torque is enough to crush it, to take up that gap. ive been trying to find a shop that will surface it, preferably a belt sander since it would be the quickest, and cheapest route, but i only found 2 shops, one with a blanchard grinder, and one with a mill, who is willing to do it, for more money then its worth, especially if the stock manifold eventually cracks. my buddy has just got a mill, but its not ready, needs to be wired into his phase converter, and he needs collets. id just like to get this done quicker, and if i can get away with no surface that would be great anyone check the gap of warped manifolds, and ran a remflex with no issues? |
| Author: | emsvitil [ Tue May 22, 2012 2:29 pm ] |
Put some wet/dry sandpaper on a flat surface and do it yourself............(an actual use for WD40 tooo) |
| Author: | kielbasa [ Mon May 28, 2012 11:50 pm ] |
got it surfaced on a blanchard grinder, found a shop who would do it for $50. took them about 15 mins.... a bit much but guess they gotta pay for the machine some how |
| Author: | jbc528 [ Mon Jul 30, 2012 9:39 am ] |
I used the remflex box gasket successfully, and also installed a thin sheet of stainess steel that covered the entire open area between the manifolds. I wanted to reduce the intake manifold's direct exposure to the exhast blast. I also wired the butterfly valve wide open to further deflect the hot gases. I still get fast warm ups(I have a manual choke), but my carb doesn't get nearly as hot and boil the fuel in the bowl like it used to without the sheet metal blocking plate. |
