fuel boil?
https://slantsix.org/forum/viewtopic.php?t=48867
Author:  mrhollywood [ Tue May 22, 2012 12:03 am ]
Post subject:  fuel boil?
My car starts fine cold but if it's warmed up its harder to start and stumbles a little. Once I start going down the road it lags a little and then it fine again.
It has had the valve lash done, timing is set at 8 btc . I don't know the idle speed...I should get a tach!
Author:  Eric W [ Tue May 22, 2012 5:28 am ]
Have you done Dans fuel line mod yet? Had the same problems with my Satellite and after doing the mod, problems went away. It could also be a float set to high.
Author:  63gtcv [ Tue May 22, 2012 6:31 pm ]
My 74 Duster did the same. Fuel line ran in front of the head and close to the exhaust, I covered it with a piece of split heater hose, all was good. Nothing is so permanent as a temporary fix.
Author:  SlantSixDan [ Tue May 22, 2012 6:49 pm ]
Do the Fuel line mod.
Author:  mrhollywood [ Wed May 23, 2012 9:22 pm ]
Ok dan,will do! I had been planning on it and had already read your link before. Just wanted to make sure that sounded like the right solution to my problem. :)
