It is currently Tue May 12, 2026 4:36 am
 Post subject: 9" Brakes tight fit
PostPosted: Mon Jan 06, 2003 8:20 pm
Car Model: 68 Formula S Barracuda
:D I have 9" drums all the way around on my 67 barracuda. I rebuilt my front brakes, and noticed that the hub fit very tight over the pads. I am not sure if there should be friction. The adjuster is retracted all of the way.
Is this correct?
Bob Brady
Slanted 67 Barracuda
PostPosted: Tue Jan 07, 2003 5:40 am
I rebuilt the front drums on my 63 Valiant last year. I had a similar problem with the pads I got from Autozone. They had given me the only set they had available for my 63.
I had them pull out a box for either a 61 or 62 valiant and the pads were noticeably smaller. I bought this set and everything went together perfectly.
John Killin
PostPosted: Tue Jan 07, 2003 3:12 pm
When properly adjusted, there should be a slight drag on drum brakes.
PostPosted: Thu Jan 09, 2003 10:39 pm
I can barley turn the drum by hand. Although I know when I drive, my brakes are working, and there is not excessive drag that can be felt. I can still push the car by hand on a level surface. I guess I don't have anything to worry about.
Any comments are appreciated.
Bob Brady
PostPosted: Fri Jan 10, 2003 6:41 am
If you can push the car by hand w/o trouble, I think you're fine.
PostPosted: Sun Jan 12, 2003 5:38 pm
Thanks for your help!!
I am kicking myself on this one!! I discovered that I installed the adjuster lower than where it should have been installed and caused the brake pads to be about a 1/8 inch out more than necessary.
When I corrected the error the hub went on as it should, with slight friction.
Thanks again!! Great website!! :lol: :lol:
Bob Brady
 Post subject: yup
PostPosted: Sun Jan 12, 2003 10:51 pm
This is why you do one side at a time, so you can readily check your work.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
