1 barrel holley (can you please check out what i got?)
https://slantsix.org/forum/viewtopic.php?t=48912
Page 1 of 1
Author:  kielbasa [ Sun May 27, 2012 12:45 pm ]
Post subject:  1 barrel holley (can you please check out what i got?)
before i tore the motor apart it was driving with a carter, that someone fixed holes and cracks with some kind of bubble gum. so i woud like to replace it. i got this holley carb off a pretty complete engine sitting in someones own personal junkyard. i am not sure if its missing anything, (seems like it might). if so could you tell me what, and if its worth hunting for, or just buying a rebuilt one.
i would like to rebuild this thing my self, but if missing parts becomes an issue. i wouldnt really wanna waste time hunting for parts. but if it looks like im good to go, what rebuild kit would i get for it?
this would be for a 1965 plymouth valiant
Author:  SlantSixDan [ Sun May 27, 2012 12:53 pm ]
Whoah, giant pictures screwing with the page formatting! If you mean to keep them this big, please edit your post to put them one per line, not side-by-side like that.
This what you're showing us is a carburetor originally from a 1963 Dart/Valiant with 225 engine. It will fit a '65 fine, but this one is missing its fast-idle cam and the link that connects the choke lever to the fast-idle cam (and the screw that holds the fast-idle cam to the carburetor).
You ought to be able to score the missing pieces without too much trouble off any-year Holley 1920; someone on here will have them for you I'm sure.
You'll need a new float, Walker #100-14. I like the kit that www.daytonaparts.com sells; it has an inlet needle/seat of an improved, more flood-resistant design. But nobody's kit contains anything like the proper float gauge any more; all you get is a useless little strip of paper ruler, leaving you on your own to try to set the float correctly :roll:
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
Author:  kielbasa [ Sun May 27, 2012 1:07 pm ]
sorry, they show small on my screen. but i changed it to 1 per line.
thanks for the input, maybe ill go diggin at the junkyard or something. the parts store TOPS AUTO SUPPLY i use to work for carries hygrade kits, ive never used them.. how are they compared to others.
Author:  SlantSixDan [ Sun May 27, 2012 1:25 pm ]
I don't buy parts store kits any more, of any brand, unless I have zero choice -- quality is through the floor.
