It is currently Thu Nov 26, 2026 1:50 am
PostPosted: Tue May 29, 2012 11:03 am
I'm going to drop the engine in my 65 valiant today, but I seemed to either mixed up or lost all my hardware Durring moving. Most of what today will consist of is just dropping it in, and bolting in motor mounts, to the auto trans, and starter. And I think there are a couple pieces like a very thin gauged plate that I believe has something to do with starter. And also a thick gauged plate shaped as a triangle.
I could really use your guys help with exactly what size pitch and length bolts/nuts I would need to pick up at hardware store. Thanks so much
PostPosted: Tue May 29, 2012 2:47 pm
6 Pack Dart
Thin metal plate goes under the starter, thick plate goes on edge of block to transmission bellhousing.
Richard
PostPosted: Tue May 29, 2012 3:03 pm
there are actually thin plates, one is small with a almond shaped hole in the center, then the bigger half circle shape, with a bite taken out of it..
id like to know exactly what bolts would be needed, if possible :-)
PostPosted: Tue May 29, 2012 3:08 pm
See This Link
PostPosted: Tue May 29, 2012 3:16 pm
ive had that link saved for a long time, would be awesome to have all the quantities noted
PostPosted: Tue May 29, 2012 4:39 pm
6 Pack Dart
"there are actually thin plates, one is small with a almond shaped hole in the center, then the bigger half circle shape, with a bite taken out of it.. "
Pictures would help!
Richard
PostPosted: Tue May 29, 2012 7:01 pm
"ive had that link saved for a long time"
Have that list mounted on the wall of my shop.
obliquely-inclined state of mind
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 5 guests
