It is currently Wed Nov 25, 2026 11:18 pm
 Post subject: 170 with 2.5 pistons
PostPosted: Tue May 29, 2012 4:04 pm
Will the 198 length rod fit in a 170, so as to use the better piston geometry?
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Tue May 29, 2012 4:10 pm
No, a 7" 198 rod will not fit. You'd have a piston compression distance of 0.45". 170 rods are only 5.7" so a 6" rod is a good choice.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 6 guests
