| Main girdle? https://slantsix.org/forum/viewtopic.php?t=48961 |
Page 1 of 2 |
| Author: | Turbo Toad [ Thu May 31, 2012 11:29 pm ] |
| Post subject: | Main girdle? |
I've been looking around on the Internet and I can't find any info on a billet main Gridle, is there any company's that make one for the slant six, would there be any interest in them if I could have a company make up some I'm interested for my turbo motor which I'm hoping to make around 600 hp at the crank But we will see Any and all help is always appreciated |
| Author: | slantzilla [ Fri Jun 01, 2012 3:18 am ] |
The only one I've seen was Howard Davis' and he did that one himself. There was a picture of it in the aluminum head thread a couple months ago. |
| Author: | CNC-Dude [ Fri Jun 01, 2012 7:51 am ] |
I've made them for other inline engines before and am going to make some up when I make one for my Slant build. Let me know if your interested. |
| Author: | Turbo Toad [ Fri Jun 01, 2012 8:17 pm ] |
Quote: I've made them for other inline engines before and am going to make some up when I make one for my Slant build. Let me know if your interested.
CNC dude when you make one up I'd take one. I'm in the early stage of a turbo motor build also I'm looking at eventually putting some serious boost in a motor and would love to have the extra insurance of tieing the bottom end togetherStanzilla I seen the Howard Davis one as well that what started me looking |
| Author: | CNC-Dude [ Fri Jun 01, 2012 10:46 pm ] |
Ok, will keep you in mind when I get started on them. Thanks |
| Author: | Brussell [ Sat Jun 02, 2012 12:01 pm ] |
Depending on how much and when you're going to do one I'm interested if it's no trouble. Cheers |
| Author: | CNC-Dude [ Sat Jun 02, 2012 3:23 pm ] |
Sure, its no problem at all. |
| Author: | John1972 [ Sun Jun 03, 2012 11:53 pm ] |
Hopefully this helps, found this slant six main stud girdle design http://www.crank-scrapers.com/Mopar%20slant%20six.html |
| Author: | Turbo Toad [ Mon Jun 04, 2012 1:17 am ] |
Thanks john I guess I never looked at the page that close and seen the pdf Aaron |
| Author: | Doc [ Mon Jun 04, 2012 9:28 am ] |
I would be interested if it also works with the Aluminum block SL6. DD |
| Author: | CNC-Dude [ Mon Jun 04, 2012 9:59 am ] |
Doc, I have one block of each(cast iron and aluminum)so I can try to make it accomodate both or make it specific for each if it cant fit both. Does ARP have a longer main stud that will work for a main girdle. |
| Author: | Doc [ Mon Jun 04, 2012 10:29 am ] |
ARP will make anything you want... as long as you have the $$$. The longer main studs for the cast iron engine should not be an issue, many different lengths are already in ARPs catalog. The Alm Block's main studs will be harder, seeing that the studs have longer theaded ends and are releived, to allow oil to pass into the cap assembles, to feed the crank bearings. DD |
| Author: | Turbo Toad [ Mon Jun 04, 2012 5:03 pm ] |
Thanks doc for the great info Cncdude there appears to be some interest please keep me posted |
| Author: | slantzilla [ Mon Jun 04, 2012 6:28 pm ] |
Quote: Hopefully this helps, found this slant six main stud girdle design
Make sure to read closely:http://www.crank-scrapers.com/Mopar%20slant%20six.html We were recently asked to design a halo type girdle for a dedicated slant six engine. A custom pan was to be made by the customer with scavenge pumps. Please note the design will probably NOT fit into any OEM slant six pan and will probably have frame clearance issues. It also does not have a provision for a stock pickup tube. Please double check all measurements and clearances. It is designed to come very close on the pressure or downstroke side of a stock 225 rotating assembly. You may have to make small notches for rod bolt/nut clearance there. It is suggested that the part be cut by water abrasive jet from cold rolled plate steel. Any warp in the plate will be bad for main bearing alignment. Mr. Johnson used to be a member here. I have one of his scrapers in my motor. All I will say is that I will never spend another dime with him. |
| Author: | John1972 [ Mon Jun 04, 2012 11:06 pm ] |
Thanks for the heads up. I have access to a.water jet cutter so if someone does design one pls advise |
| Page 1 of 2 | All times are UTC-07:00 |
