| Fuel gauge and sender info. https://slantsix.org/forum/viewtopic.php?t=49009 |
| Author: | Shrug64 [ Thu Jun 07, 2012 7:15 pm ] |
| Post subject: | Fuel gauge and sender info. |
Ok, the fuel gauge and sender in my 1952 Chrysler are not working. The gauge will be fixed when I rewire the car next month, but I took the sender out and it is pretty corroded. For now I do have a fuel gauge, Ford/Chrysler type, 81449. I would like to get an universal sender to work with it, but I do not know the ohm range. Also is my aftermarket gauge the same ohm range as my factory one or will I need to change senders again? Any info would really help! Thank you. |
| Author: | Shrug64 [ Thu Jun 07, 2012 8:36 pm ] |
Oh, also, is it possible to mount one of those universal senders to my original tank? |
| Author: | Mroldfart2u [ Sat Jun 09, 2012 7:00 am ] |
| Post subject: | Re: Fuel gauge and sender info. |
Quote: Ok, the fuel gauge and sender in my 1952 Chrysler are not working. The gauge will be fixed when I rewire the car next month, but I took the sender out and it is pretty corroded. .For now I do have a fuel gauge, Ford/Chrysler type, 81449. I would like to get an universal sender to work with it, but I do not know the ohm range If the gauge IS in fact a ford/chrysler compatible gauge the factory ohm range is 10-73 ohms.(not knowing what brand of gauge you have) Empty being 73ohms... (not exact but within a small tolerance) The universal sender can be used if thats the range it operates in... Quote: Also is my aftermarket gauge the same ohm range as my factory one or will I need to change senders again? Quote: Any info would really help! Thank you. |
