Wiring
https://slantsix.org/forum/viewtopic.php?t=49013
Author:  Big T [ Fri Jun 08, 2012 7:24 pm ]
Post subject:  Wiring
Need some input here..
I have installed a GM/DENSO style 50 AMP Race ALT on the 67 Dart, it is a one - wire... Do I wire it to the Starter directly by way of a toggle switch? Or do I wire it to the Master Cut off switch? Also what gauge wire should I use???
Thanks....
Author:  Charrlie_S [ Sat Jun 09, 2012 4:32 am ]
If you have a trunk mounted battery and a rear cutoff switch, the alt. wire should connect to the pos battery terminal, or the battery side of the cutoff switch. I would use a minimum of 8 gauge.
Author:  Big T [ Sat Jun 09, 2012 6:42 am ]
Thanks Charlie..
Yes it is trunk mounted ... I wasn't sure what gauge wire I should use...Thank You...
Will give me something to do today while the girlfriend goes for her sat ride on her Sportster
