oil light
https://slantsix.org/forum/viewtopic.php?t=49036
Page 1 of 1
Author:  Junior [ Mon Jun 11, 2012 3:46 pm ]
Post subject:  oil light
so i went racing this weekend, the motor was running really good. running good in the pits running good in the staging lanes running great on the run, get through the traps and the oil light comes on stays on the whole trip down the return lane till it get back to the pits. while all this is going on i have a mechanical gauge that is reading 50 psi the whole time and goes up to 55 when i goose it. motor sounds fine if the light never came on i would not have known anything was up. ran it all day with no problems. why is the light on?
Author:  Fopar [ Mon Jun 11, 2012 3:55 pm ]
Wire came loose and is grounding?
Richard
Author:  Doc [ Mon Jun 11, 2012 3:57 pm ]
The oil pressure light operates off a "controlled ground" so inspect the wire carefully to be sure it is not grounding out at any point, on it's way to the sending unit.
If the wire checks-out OK, replace the sending unit.
Author:  Junior [ Mon Jun 11, 2012 6:26 pm ]
ok sounds good ill check tomorrow. thanks for the replies
