| A/C Setup on my '66 Dart (I think u will like it :) ) https://slantsix.org/forum/viewtopic.php?t=49042 |
| Author: | 1966DartConvertible [ Tue Jun 12, 2012 8:45 pm ] |
| Post subject: | A/C Setup on my '66 Dart (I think u will like it :) ) |
Installed the A/C system with a friend during this last weekend... here are some pictures: ![]() ![]() ![]() and here are some more pics, (engine bay) ![]() ![]() ![]() ![]() ![]() I also manage to remove the distrubutor which has been giving me trouble lately ![]() ![]() What do you think? Syed |
| Author: | SlantSixDan [ Tue Jun 12, 2012 11:05 pm ] |
Interesting low-mount compressor bracket. Did you make it, or buy it? If bought, where? I "think" your distributor is a Prestolite IBR-4203G. What would you like to know about it? |
| Author: | 1966DartConvertible [ Wed Jun 13, 2012 6:25 pm ] |
Quote: Interesting low-mount compressor bracket. Did you make it, or buy it? If bought, where?
The bracket was locally fabricated and looks like this: I "think" your distributor is a Prestolite IBR-4203G. What would you like to know about it? ![]() Thats the old solex carb by the way. As for the distributor, yes you are correct its Prestolite. I was having trouble with the ignition timing going crazy, like advancing by itself once I drove more than 15-20 miles and will start pinking badly. When I use the timing light to time it, the "flash" moves all over the place too, so I cant time it properly. The timing chain is new, the harmonic damper is new, belt is fairly new. Plug cables is less than 6 mths old. I think the plate at the bottom of the distributor is "moving" or one of the spring inside the dizzy is missing/broken... which is why I took the dizzy out. Syed |
| Author: | SlantSixDan [ Wed Jun 13, 2012 6:33 pm ] |
Good opportunity to pick up a new electronic dizzy from Old Car Parts Northwest
