| Break in Lube https://slantsix.org/forum/viewtopic.php?t=49105 |
| Author: | kipamore [ Sat Jun 23, 2012 5:28 pm ] |
| Post subject: | Break in Lube |
Here's an easy one. I'm making progress on getting the turbo wagon back together. The engine is on the stand, and I'm about to put the oil pan on. This block has been sitting without oil for 5 years, but it's clean inside. Is there anything I might want to baste it with while I have it on the stand. Some folks say lithium grease, some folks say lithium grease isn't oil soluble so I shouldn't do that. Anybody recommend anything, or should I just squirt it with motor oil and hand spin it till it gets up pressure? Kip on Truckin' |
| Author: | tyb525 [ Sat Jun 23, 2012 10:03 pm ] |
Gear oil, motor oil, or "assembly lube" would probably be best. |
| Author: | kielbasa [ Tue Jun 26, 2012 11:38 am ] |
For brand new engines, I use my own blend of assembly lube, brad Penn and Lucas. It's very slick and very sticky. It will never run off while sitting for years, I've checked. And I also use comp cams break in zinc additive for lifter/cam |
| Author: | DusterIdiot [ Tue Jun 26, 2012 6:27 pm ] |
| Post subject: | Isky |
Isky makes an assembly compound that incorporates moly in it called "Rev Lube". It's good stuff. -D.Idiot |
| Author: | kielbasa [ Tue Jun 26, 2012 8:26 pm ] |
Forgot to mention I use arp grease for cam and lifters, and I make sure they got a lot on them. It's just moly grease, good for cam break in |
