It is currently Tue May 26, 2026 11:25 am
PostPosted: Sat Jun 23, 2012 11:52 am
Changed my holley carb to a carter and what a difference. The only problem
is I dont have bolt to attach the air filter , and there is no threaded hole
inside the carb so it would have to be mounted around the rim :?: I bought
it through Napa and they couldnt point me in the right direction
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Sat Jun 23, 2012 12:07 pm
Sounds like you need the air cleaner bail. It is a roughly half-circle shapes thick wire that arches over the throat of the carb and holds a bolt in place over the center of the carb throat with the threads pointed up. You should be able to grab the bail off of just about any 70s or 80s era Carter BD, Holley 2280, Holley 1920, or Holley 1945.
PostPosted: Sat Jun 23, 2012 12:19 pm
If it isn't one of those older ones, that had a "clamp on" air filter...
I have no idea what I am talking about.
PostPosted: Sat Jun 23, 2012 8:30 pm
Remove the air cleaner bail from your Holley carburetor and put it on your Carter.
