Head Gasket Question
https://slantsix.org/forum/viewtopic.php?t=49162
Author:  DusterIdiot [ Fri Jun 29, 2012 8:17 pm ]
Post subject:  Head Gasket Question
Starting to do more than head scratch on a higher compression engine...
Looking over the various builds, about how much compression can a head gasket take before you need to O-ring the block (let's disgard boost for sake of this topic).
The victor Reinz gasket is holding well in my current 11.7:1SCR motor, I know the Felpro gasket seems to be OK into the 10's but I had the head gasket give during break in on an 11:1 motor...(So I'm more of a fan for Victor and Aussie at this point if over 10:1)
I saw a topic where Romeo had used a .020 gasket for his 13.2:1 mill, but he didn't say it was a copper gasket or shim....
I know the Aussie gasket is well put together and I think it might hold up to the 12's.
Anyone know where the upper boundary is for using an over the counter head gasket?
THanks
Author:  Dart270 [ Sat Jun 30, 2012 4:05 am ]
I have run several different composite gaskets up to 11:1.
Tilley said the Permaseal was good to the 12s:1, and he usually uses an o-ring on one side that hits the fire right (head side, IIRC). I have one on the 11:1 motor in Project V. I think many of the TN guys have run composites to 12:1, even FelPro. Seymour uses Corteco and his motor is over 11:1.
Author:  Romeo Furio [ Sat Jun 30, 2012 5:49 am ]
I ran the steel shim coated with Hylamar(I'm sure I spelled that wrong) but after a few passes leaks started. A.040 Felpro permatorque replaced that wanting to lower the compression a bit along with a few other changes for longevity and have had no problems. Greg has a copper but I don't know if that is what he is running at the moment.
Author:  Greg Ondayko [ Sat Jun 30, 2012 6:38 am ]
I have run Fel-Pro and Aussie/ Permaseal Big Bore on Ruster with 12.5:1 No issues with either :-)
Author:  Will [ Sat Jun 30, 2012 6:46 am ]
I agree with everyone. If the surfaces are flat it will work. An o'ring just on the edge of the copper band will hold over 13 to 1.
Will
Author:  DusterIdiot [ Sat Jun 30, 2012 10:41 am ]
Post subject:  Thanks guys!
Much appreciated for the input from the guys in the know. Seemed like a good question to ask before planning the 'next' step.
:wink:
