| Aspiration https://slantsix.org/forum/viewtopic.php?t=4923 |
| Author: | cycledog [ Sun Feb 02, 2003 7:40 pm ] |
| Post subject: | Aspiration |
Anybody out there ever try running a Quadrajet on a 225? |
| Author: | 60Pioneer [ Mon Feb 03, 2003 7:44 pm ] |
I've been hanging around here for about a year and haven't heard of anyone running one. I'm assuming that you have one "in hand". If it were me, I'd take it with me to a swap meet and see if I could pick up a 390 Holly or 500 Carter in trade. While this thing may be OK on the Primaries, I don't think you'll be too happy when the secondaries open up. Just my $0.02 Gilly |
| Author: | Slant Cecil [ Mon Feb 03, 2003 7:57 pm ] |
The 4 barrel Q-Jet may be too big for a slant, but what about the 2 barrel Q-Jet? If the fuel distrubution is OK with one, the small primary might give a good mpg return while the huge secondary will give the power most slanters would like. Mopar did use Q-Jets on some 80s 360 V-8s. Cecil |
| Author: | rustycowl [ Tue Feb 04, 2003 9:11 am ] |
| Post subject: | Tq |
They used ThermoQuads on 318s, along with 4V Q-Jets. You can slow the secondaries opening. If I had something to try it on, I'd give it a try. They also had an aftermarket 800cfm TQ with electric choke which would be more convenient to adapt. |
| Author: | kesteb [ Tue Feb 04, 2003 2:09 pm ] |
The q-jet was used on the Pontiac 230/250 OHC engines and the Buick 231/252 V6s. The secondaries were pined so they wouldn't open all the way. They were rated at around 650 cfm. The Mercedes l6 used a spreadbore solex 4bbl before it went to EFI. All of these engines had the secondaries facing the engine block. Clifford at one time, offered a spreadbore adapter for their manifolds. There is no reason a q-jet won't work on a \6. The primaries are relatively small, and the secondaries are vacuum controlled so they won't open up, unless there is a demand. |
