| rear driver's side turn signal/brake light not working? https://slantsix.org/forum/viewtopic.php?t=49246 |
| Author: | Brovender [ Sun Jul 08, 2012 10:48 am ] |
| Post subject: | rear driver's side turn signal/brake light not working? |
I have a 1973 Dodge Dart Custom (/6) and all of a sudden only my rear driver's side lights stopped working. The running lights still work though. I've replaced the bulbs, checked the grounds, everything seems to be as normal. Does anyone know what could have caused this? Thank you in advance! |
| Author: | wjajr [ Sun Jul 08, 2012 11:01 am ] |
A worn directional signal switch is a suspect when rear lights don’t function properly after wiring, grounds, and bulbs are found to be good. |
| Author: | Brovender [ Sun Jul 08, 2012 11:05 am ] |
Thank you so much! |
