It is currently Sun Nov 29, 2026 3:34 pm
PostPosted: Fri Jul 20, 2012 3:04 pm
Car Model: 1969 Dart 340, 1975 Dart 225, 1967 Dart 225
I am mocking up a super six with a 1974 BBD for my 1975 slant six. I am making sure that I have the vacuum lines set up correctly.
When viewing the carburetor from the front where the fuel line enters the float bowl there are two vacuum ports:
Canister purge between the idle mixture screws
The air pump diverter valve (which I have capped)
http://i748.photobucket.com/albums/xx12 ... C06699.jpg
When viewing the carburetor from the side with the choke diaphragm there are two vacuum ports:
The float bowl to canister
The distributor
http://i748.photobucket.com/albums/xx12 ... C06700.jpg
When viewing the carburetor from the back side looking at the curb & fast idle adjusting screws there are are three vacuum ports:
The PCV
Heated Air
The choke diaphragm and egr t-ed together
http://i748.photobucket.com/albums/xx12 ... C06702.jpg
A few more pictures:
http://i748.photobucket.com/albums/xx12 ... C06703.jpg
http://i748.photobucket.com/albums/xx12 ... C06704.jpg
Do these vacuum ports sound correct?
I also have a cast iron intake manifold and an aluminum manifold are there any benefits or disadvantages to using one over the other?
Chris
PostPosted: Fri Jul 20, 2012 3:10 pm
I think you've got the ports correct -- Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download, and there's a BBD book in the collection.
Aluminum's nicer if it's unwarped and uncracked. If it's the yellow one in the pics, it's one of the EB-welded intakes (prominently visible weld bead all around the upper perimeter of the manifold) so it will want very careful inspection for cracks in the floor.
PostPosted: Sat Jul 21, 2012 10:44 am
Thanks Dan, I was most concerned with the choke diaphragm and the egr being fed by the same vacuum port but I have found some information that seems to support the idea that they indeed did share the same port on some applications.
I have read about the problems you mentioned with the aluminum manifolds, I am going to media blast the manifold to remove the yellow paint and after washing the manifold I will check for cracks inside and outside of the manifold.
http://i748.photobucket.com/albums/xx12 ... C06730.jpg
Thanks for the help,
Chris
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 8 guests
