| junkyard engine https://slantsix.org/forum/viewtopic.php?t=4934 |
| Author: | dodge_this! [ Tue Feb 04, 2003 2:29 pm ] |
| Post subject: | junkyard engine |
I have an 85 dogde ram with a 225. I just found another truck like mine except its an 80, and it has a manual transmission. The only thing different I can tell about the engine from mine is it has a different valve cover. Will this engine bolt up to my automatic tranmission. Is this engine even worth getting and trying to rebuild. |
| Author: | Doc [ Tue Feb 04, 2003 4:36 pm ] |
| Post subject: | Re: junkyard engine |
Quote: I have an 85 dogde ram with a 225. I just found another truck like mine except its an 80, and it has a manual transmission. The only thing different I can tell about the engine from mine is it has a different valve cover. Will this engine bolt up to my automatic tranmission. Is this engine even worth getting and trying to rebuild.
Yes and Yes...The 80 SL6 has a cast crank but that is not a big problem. DD |
