hydro lifter/solid cam?????
https://slantsix.org/forum/viewtopic.php?t=49349
Page 1 of 1
Author:  hantayo13 [ Thu Jul 19, 2012 10:25 am ]
Post subject:  hydro lifter/solid cam?????
can I use hydro lifters on a solid grind cam ????? any of you gurus got an answer
thanks
Indian
Author:  THOR [ Thu Jul 19, 2012 11:59 am ]
I wouldn't.
If I recall, the hole drilled in the rear journal is larger on the hydraulic cams to allow more oil flow to the rockers, and subsequently, the lifters. There is also a special stepped bolt for the rear of the rocker shaft to allow more oil through.
To run the hydro lifters properly, you would need the remaining parts for the hydro set-up, which includes a hydro cam, and non-adjustable rockers.
~THOR~
Author:  hantayo13 [ Thu Jul 19, 2012 2:02 pm ]
already have the other parts am wondering if I can un my 276 dur purple solid cam in hydro engine or do I need to change vavle train to solid?????
Author:  Joshie225 [ Thu Jul 19, 2012 5:14 pm ]
That old Mopar grind needs a lot of lash to run properly and you get around .006" effective lash give or take with hydraulic lifters. Definitely run that cam with solid lifters and an adjustable valve train.
