| '77 1bbl vacuum lines newbie questions https://slantsix.org/forum/viewtopic.php?t=49397 |
| Author: | Nomad [ Tue Jul 24, 2012 7:06 pm ] |
| Post subject: | '77 1bbl vacuum lines newbie questions |
I am looking to refresh all of the vacuum lines on my van. I disconnected and measured all I could, but still have a few potentially dumb questions: 1/ PCV line is cracked and probably leaking. Should I replace it with the same 5/16" fuel injection hose SlantSixDan recommends for the fuel line mod or another type will do? 2/ Air cleaner, choke pull-off and distributor hoses seems to be 3/16" ID. The outside diameters are different though, should I care? 3/ Other hoses still have their colored stripes (white, blue and yellow) and given their condition, they probably are the original ones. I think they all are 3/32", but I wasn't able to disconnect them separately since they merge into one piece that connects into the Vacuum amplifier. Same problem at the CCEGR valve. Am I missing something obvious here? How can I replace them? 4/ Carburetor to ECS, any type of hose I should use in particular? ![]()
| Author: | Reed [ Tue Jul 24, 2012 10:20 pm ] |
I will go out on a limb and say regular vacuum hose will work for all the connections, no need for the special fuel injection line hose since none of these hoses will be carrying fuel. I will also posit that it is the inner diameter of the hose that matters, since that is what is necessary to make a tight connection to the fitting. As far as the connection to the vacuum amplifier goes, you may be better off trying to find a good condition used assembly. I am not aware of a way to disassemble the connecter hat goes to the hockey puck. |
| Author: | SlantSixDan [ Tue Jul 24, 2012 10:51 pm ] |
The PCV hose needs to be oilproof; regular plain rubber hose will swell and degrade quickly. Fuel line hose is fine, too, but no need to get the expensive fuel injection stuff. The correct diameter is 11/32", but that's often hard to find so 3/8" with appropriate hose clamps is an acceptable substitute. The breather hose (from crankcase breather to air cleaner) needs to be actual breather hose -- oil resistant. Not heater hose. Everything else: plain vacuum hose. |
| Author: | Reed [ Tue Jul 24, 2012 11:19 pm ] |
No wonder some of the vacuum lines I replace start to get sticky after a few months. Thanks for setting me straight. |
| Author: | Nomad [ Wed Jul 25, 2012 4:50 am ] |
Thanks so much, guys Quote:
So, either I keep the EGR setup the way it is and eventually find one in better shape at the junkyard, or I'll have to bypass the whole thing? |
